Barter for aluminum Radiator
nash421
What do you guys do to help keep temps down in the summer? I have a 160 stat and wrapped downpipe (partially). I ordered a heat shield, also flushed rad multiple times and put in water wetter. Anything else I can do without buying an aluminum radiator? Just dont have the money for that kind of purchase right now. Or if any1 is willing to barter I have some parts, guns, etc to trade. Thanks!
Hold old is radiator? What does the core look like on the inside?
have you wired your OE fan for high speed
better yet go with the valeo dual fans from the 98 dodge intrepid, trim off the mounting ears, cut plug from your old OE fan
best then is hotwire the fans . racetronix makes a nice dual fan hotwired harness that once you intall the supplied OE style fan plug its a plug and play setup that will run in low speed at normal fan on and with AC on will run in high speed if you really need more you can wire the high side relay ground to the low side relay and those fans will run in high speed
