Battery Cables
87we410877
Looking for a set of battery cables? I need the stock, Factory positive from the battery to the starter, alternator and ECM, and also the Negative from the battery to the fender ground and front head.
Let me know! Thanks
Tyler 516-356-6238
Kirbans performance has the battery cables $115 if you can't find any used ones.
You might try PMing m233roller, Mike might have what you are looking for as well, and great to deal with.
You might try PMing m233roller, Mike might have what you are looking for as well, and great to deal with.[/QUOTE
Do you know if those are factory lengths? I have seen the positive cable in the past from caspers and the alternator wire is way short to go straight to the alt. as opposed to under the front of the motor and attach to the oil pan. I bought a negative cable and the ground to the head is way short.
Thanks in advance!
Tyler
I saw those perusing their site so I can't say to the lengths. I would check with Mike (m233roller) or Fred (GNX026).
Both those guys have a lot of good condition factory stuff.
Thanks for the info. They Kirbans look legit. I may just get those as this is a factory resto.
Nice! You could always call Dennis to see about the lengths as well.
He does sell Caspers products so it might be worthwhile to check.
I have a stock new set or slightly used (1500 miles ) 100.00 new 75.00 used plus shipping will send pics if interested.
