Just got my 86 back from body and paint. Near perfect, Decided to change to a Delco Battery to finish the under the hood look. I never liked the bright red battery spoiling the original look. While changing I noticed that the small ground wire from the negative terminal was not attached to anything so when the new battery went in I grounded it to one of the bolts along the fender edge just under the hood line. So I got to wonder. What is the effect of that wire not being connected? And are there any other ground wires I should check out? Probably dumb questions but I appreciate any guidance.
Herein some pics of the finished product along with some examples of what you find underneath a seemingly good body when you take it apart.
