Well I am having a strange problem with my T Type. For some reason I can not get the battery to hold a charge. I think it is possible that it has something to do with the dash but I wanted some input before dumping the money into it. So i'll go into what it's been doing to me. This is a digital dash by the way.
The first thing to go wrong was it was throwing up random numbers for my mileage on the trip odometer. But that didn't bother me because I would reset it and it would be ok. Next thing a little bit later was the dash died completely. I took it out, cleaned the points, and reinstalled it and it worked fine but still gave random numbers on the trip. I let the car sit for a while and then when I went to start it up it wouldn't do it no matter what I did. Long story short it turned out the large ground on the front of the motor came loose. I tightened it up and then the car would start but now it won't charge. I tried a new battery and rebuilt the Alt with a 200 amp upgrade and still nothing.
The only other thing I read about was that if the bulb went bad on the dash for the volts then it might cause a problem. I turn it to run (Right before start) and got nothing. No bulb. I opened it up and the bulb looked fine. I put it in another socket that was lighting up and it lit up. And no matter what the volt light won't come on. At this point I have no idea where to look next. I checked every ground and they are all fine now.
Thanks in advance for any help at all on this one. It's driving me nuts!
