As some may recall, I had a piston go south in my GN, and will be replacing it with a used stock piston/rod (THANKS Jerryl!!) after honing the cylinder bore in question.
I got the old piston pulled today, and luckily the old bearings look in pretty good shape. There is some wear, but no big hunks of metal imbedded, and no copper showing, so in my book that seems pretty good. Below is a picture of the rod journal on the crank so you can have an idea of what it looks like (bearing surface looks about the same).
My first question regards the bearings. I just bought a set of standard bearings, since I know my replacement rod is standard sized, and since the previous owner had replaced the crank (with reciepts to prove it) I assumed it would be standard sized as well. When I pulled the old bearing, it is marked "020' on both halves of the shell, so I assume this means the crank has been ground/turned down 0.020"? And this means I need to return my std. bearings for 0.020 oversize bearings? I'm pretty sure about this, but the few engines I've messed with all used std. size bearings so I want to make sure I dont screw it up.
My second question has to do with rings. I bought a set of Sealed Power WE434K rings. Do these come with the proper gap already, or do I need to test fit them and file them to proper gap? If so what gap do I use? Also, what is the best method for installing the rings on the piston? Is there a special tool I can rent from the parts store, or can you just twist them on by hand without deforming them? For the compression rings, I think I remember reading you install them with the 'dot' side up? The two compression rings have different sized gaps, and different colors painted on them near the end:
smaller gap - one end red, the other white
larger gap - one end yellow, the other no paint
Which is the upper ring, and which is the lower? When it comes to the oil control rings, there are no marking to denote top vs. bottom, and the two thin rings seem identical, does it matter which ring is on top of the corrugated part and which is under? Does it matter which sides face up? And lastly, the corrugated oil control ring came with what appears to be a small piece of clear plastic attached to the first corrugation near the split on each end , one painted green, the other maybe white. Do these need to be removed before installing. or do they go in as is? and again, does orientation of the corrugated ring matter (which side faces up)?
Heres a pic of the ring pack, in case none of that made sense:
I didn't even notice until looking at the picture, but it seems both the thin oil control rings have one of their ends painted yellow as well.
Sorry about the million questions regarding the ring install, but this is my first time putting in rings, and I obviously want to make sure I install them correctly. ANY help deciphering where each ring goes, what its orientation is (which side faces up) and how to install it onto the piston will be VERY helpful.
I assume once they're on the piston, getting it in the cylinder is a simple matter of using a ring compressor and sliding it all back in.
Thanks for the help guys!
![IMG_0662.jpg](/proxy.php?image=http%3A%2F%2Flh6.ggpht.com%2F_BTqsOmVwP8I%2FSnjNYvoTVkI%2FAAAAAAAAEVs%2FIAzniW9H74Y%2Fs640%2FIMG_0662.jpg&hash=6362f837f71f4e5cec2d5bd93f8a3704)
