I like the HV pumps as long as the engine can use it. Oil pressure is useless without flow but if you build an engine that can flow the oil you'll get better cooling of the bearings. Running a standard pump on a looser engine is kinda like trying to run a small turbo on a big engine. It'll only make so much pressure. If it can keep up great. If it can't then step it up. A 0w-30, 5w-30 and a 10w-30 oil are the exact same thickness at operating temp. You just need to decide how thick you want the oil when it's cold.
I worked my front cover over (earls front cover mods) and made sure the clearances in my pump were good. I used an HV pump. I opened up the mains to match the block (I think I only did this to the centers) and I used the TA performance dual groove cam bearings that relocate where the oil gets introduced on the cam journal. If you get those make sure you follow the instructions instead of going for hole alignment like you would on normal cam bearings.
Anyway, I made sure my oil passageways didn't have anything like the cover gasket hanging into them and in general just eliminated as many lips as possible. I set my mains/rods out to around .023-.025. End result? I run a 0w-20 oil and on start up I have around 80 psi of pressure. After driving it comes down to about 20 psi stopped in drive and as soon as I hit the gas it climbs
fast. Oh yeah, I still haven't gotten around to installing an oil cooler.
