First thing, break in the cam
First time you crank it up you need to break in the cam ASAP. If your valves are set reasonably close then it should be not problem. Run the engine over 2000 RPMs for 20-30 minutes, then the cam is broken in. Next thing I did (this is on big or small block Chevy but should apply) is double check the valve lash with things hot. Next, I changed the oil and fileter to get any crap out of the system, break in lube, metal from breaking in rings/cam, etc. Then drive it like you wanna drive it UNLESS one of your new components has some other recommended break in. In the case of my Corvette the CenterForce clutch required a 500 mile break in, so no burnouts for 500 miles.
Jeff
To clarify one more thing...you can wait to start the engine or you can start it right away. If you told the engine builder it was going to be awhile hopefully he used plenty of break in lube to keep everything well coated for the wait.
