Can I make Stage II heads run on the street?
Dynoman,
Thank you very much. You made that easy. Just looked over the Dominator ECU at Holley’s site - impressive to say the least. Controlling alcohol injection, and 80E transmission, what more to ask for? Just helped to determine which tranny to run too!
Edie - Not 100% sure on tranny. I have two 200-4Rs (GN valve bodies) and two 4L80Es to choose from to build. If the 200-4R can be made strong enough, I think the main advantage will be the weight by saving 100lbs. Am I correct with this? Either way will need a tranny built. It was recommended to go with a LD 200.. I do have a 9” single-disc lock up TC here, can’t recall the name of it, but it’s purple.!!
Myself and Mr Spool run Dave Husek's 200-4r . I've made 990hp and Spool makes more . My car is full weight +3700lbs and his is much lighter , that being said , a lighter properly geared car will be much easier on the trans which will be in your case .
