Before and after times/mods...
  • Thread starter Thread starter GRAYGHOST
  • Start date Start date
G
GRAYGHOST
Guest
When I first got this car it had the following parts on a stock 100K motor:
TE-60
009's
3" THDP, 3" single shot
stock intercooler
Walbro 307 hotwired/voltbooster
2800 stall D-5 converter, PMAC built trans
completely stock suspension, rear airbags, 90-10 fronts. 15" weld draglites.
Ran this on 93 octane at 18 pounds boost with a 20 degree chip got a: 2.0 60', 8.68 @ 81 MPH on street radials. Slicks netted a 1.77 60, 8.21 @ 83 MPH.
Fast forward to tonight and the following changes:
PTE-54
50's
Added 100# valve springs
PTE front mount intercooler
3200-3400 stall 9/11 converter
Reds dual 340's, hotwired/voltbooster
2" drop spindles in front, H&R parts lower billet control arms, boxed uppers, w/poly bushings, ATR rear sway, poly body bushings all the way around, Bilstein shocks all around. 16" Torque thrust II's. 255-50-16 drag radials on all runs here:
Now after a couple runs trying to figure out where to launch with this converter and all, I got a 1.73 60', 7.95 @ 87 MPH, with 18-19 pounds boost, 20 degree timing on 93 octane. Then a 1.77 60', 7.81 @ 90 run with 20-21 pounds a boost that run. I ran the tire pressure down to 14 psi for these also. Launched at 3500 RPM's with 2-3 pounds boost then eased in it. She picked up a little too as the night got a little cooler. I first started in the sunlight, ended nightfall, car ran around 180 degrees temp. about every run. (dual fans going on soon). Drove 30-40 minutes to track.
I was pretty impressed with the 60's I got considering the 2" drop spindles, and the bilsteins in front. I did take the front sway bar off the later runs, but with the rear set up now you would never know it on the street!
Next is a dual nozzle alky kit and some fine tuning and hopefully some mid 7's mid 90's?? Oh, some fiberglass parts and peices here and there are also going on now too!!!:D
Then some 116 octane and some 6's with high 90's, maybe even triple digit MPH!!:eek: BOOST BABY BOOST!!!!!!!! I ain't skeered!:D
Originally posted by stevemon
Warp6,
I get your drift and also think Grayhost's car is running pig rich.
actually, I was just saying his car is a pig...ha!
o2's where hovering right around 800 on most all of these runs. I was thinking on pump gas this was not bad. I don't want to lean it out with this 54 blowing 20 psi..............Now if I had some 110 or more octane, uh, low 7's definitly!
Hey Craigie, did you get back to sleep ok last night, did paw-paw have to take another sleep-aid?:p
that's nice...you call me from a dead sleep at 10:30...(gotta get up at 5am) to brag on a slow-a$$ pos. Did Kevin get a tetanus shot before he rode to the track with you in that tank?
PS- did you try your reverse burnout trick at the track? moron:rolleyes:
I wasn't bragging old man, I was actually calling to get your opinion on what you thought about the times. Your just like a bitch, try to be nice or give a little credit to somebody, have a little respect since I think you know more about TR's than me, and what do I get? Trampled on just like a woman would do. Thanks.
Bragging...huh...whatever, I asked you what you thought about the times, how's that bragging? A$$HOLE.
By the way, your pimp daddy did not go with me to the track, I think he was digging your mama out...:eek:
okay, here's my opinion: You have a load of crap on that car to be so slow.
I ran 7.93 with the following mods:
chip
k&n filter
crushed stock regulator
external Bosch fuel pump
adjustable wastegate rod
160 thermostat
pump gas with 104Super octane booster
Completely stock unopened engine
Scan tool:none
Turbo:stock
injectors:stock
downpipe:stock
converter:stock
exhaust:Hooker with Hooker turbo muffs
tires: General 245/60/15 radials
airbag in passenger side rear spring
Blake Gann's GN with the same mods (except he has stock exhaust) went 7.80's
And by the way Mikey, I'm just giving you a hard time buddy. I still love ya'
Kevin said that he has not had his shots so he declined to go with you to the track:D
tune ....tune.... tune...your on the right track mike!....as far as opinions...I have a few:rolleyes: ....just turn that mutha up!...later joe
