Beginning the tuning process
timstips
Do you try to tune the SMC alky kit, the very first time, from a dead stop and go through the gears or go from around 65mph in 3rd gear? If you get it right in 3rd gear at wot, will it also be right in 1st and 2nd gear? If I'm a little rich at wot in 3rd gear and also getting around 5 degrees of knock what is the solution? Sorry for all the questions, just don't want to blow it up. Thanks.
I started from a dead stop and tuned from there, as i have it now, my turn on is at 13 lbs and my pump speed is at 8. Seems to work good like that for me, but yours may be diffrent.
Kevin
What size nozzle is in there, what is your turn on point, and what is your pump speed.
And what chip are you using, and what is your max boost
