Jul 27, 2010 #1 5 50psi Member Joined Nov 18, 2009 Messages 93 Does anybody know what size belt to use when you delete the ac pulley and air pump pulley?
Jul 27, 2010 #2 M mat231v6 painter Joined Jun 17, 2006 Messages 3,589 50psi said: Does anybody know what size belt to use when you delete the ac pulley and air pump pulley? Click to expand... i use a belt for a 1985 buick regal n/a 2bbl motor 8th vin number A. try that. i think it will work. I'm not sure but you can allway return it if it doesnt work.
Jul 27, 2010 #3 FlintBuick4Life Active Member Joined Aug 26, 2009 Messages 1,306 You shouldn't need one then if you remove it... I guess it depends on how your setup is. Do you have a smog pump?
Jul 27, 2010 #4 C CamoDeafie New Member Joined Jan 7, 2010 Messages 940 I was wondering if he had a serpentine belt system instead of the V belt system...
Jul 27, 2010 #5 5 50psi Member Joined Nov 18, 2009 Messages 93 here is a pic, now minus the smog pump
Jul 27, 2010 #6 FlintBuick4Life Active Member Joined Aug 26, 2009 Messages 1,306 Oh ok, I have one for what you are doing... had it for my alum alt bracket with no A/C. I will get the number tomorrow for you. It was a pain to find
Jul 28, 2010 #8 FlintBuick4Life Active Member Joined Aug 26, 2009 Messages 1,306 50psi said: thanks man much appreciated Click to expand... I will have to look more tomorrow, I couldn't find it today... my garage is a mess right now, I`m redoing the roof on it.
