For a bone stock car, the best chip is a stock one. If you plan to add any kind of performance chip, at a minimum you need an upgraded fuel pump, a 237 regulator (Or preferably an adjustable one) and the "Spring Cleaning" found on gnttype.org done.
The stock fuel system from the factory was inadequate. Couple that with age of the cars and the performance available from aftermarket chips and you have some problems.
Also, since you only have access to 91 octane, you will need something custom done to handle your situation. Contact any of the custom chip makers and I'm sure one of us will be able to take care of your needs.
