best converter for me?
WO2TURBO
my set up is in my sig. im looking for some input as to what would work best for my set up. the car dont see a whole lot of track time, but when it does id like to have that little extra. thanks chris
a 3000 stall will work well with that combo.if you are interested in a converter give me a ring.we have quality pieces are are now making all of our 12 " and 10.5 " converters in house.
You have two choices really:
Choice 1: A 12'' d-5 put no higher than 2800 rpm, myself i'd shoot for 2600. Really, anymore than 2800 in a 12'' and the efficiency of the converter goes away pretty quick.
Choice 2: a 9.5'' set at 2800 - 3000 {that should cover 375 -450 ft lbs of Engine torque}.
Either converter would work great with your combo and make the car feel like a super torque monster above and beyond what it is already.:D
10.5” HIGH PERFORMANCE STREET CONVERTER #24RC/HPSB $599.00
This converter is designed for high performance street applications. Its unique design makes it more efficient in the lower rpm ranges when cruising making it a true high performance street converter .It is custom built for each application to any stall speed between 2800 and 3800 rpms. The converter is assembled with a heavy duty lock up clutch, oversize needle bearings, furnace brazed fins and a hardened hub and will handle up to 500 foot pounds of torque.
