May 22, 2006 #1 H hboost Banned Joined May 10, 2004 Messages 316 I currently have 55lb. injectors and was wondering if I should upgrade since I'm swapping turbos and am going to be using a 45a. Any thoughts, comments, suggestions, recommendations?
May 22, 2006 #2 B Bobs rare 6 Member Joined Apr 11, 2004 Messages 654 Im using 55# with 45-a q-trim. Helps if your using alky ! Bob.
May 22, 2006 #3 B Blazer406 Mechanical Engineer Joined May 2, 2002 Messages 5,068 What is your boost level ..... hp level......? If you have all the right parts.... the TE45A is an easy mid 10 sec turbo..... 50# is light IMHO...... 72# or so would be good ones.......
May 22, 2006 #4 H hboost Banned Joined May 10, 2004 Messages 316 My engine has stock internals, and max. boost I want to push is about 23lbs. I'm not really interested in maxing my car out, maybe mid to low 11's.
May 23, 2006 #5 B Blazer406 Mechanical Engineer Joined May 2, 2002 Messages 5,068 55# injectors should be adequate then..... IMHO
May 23, 2006 #7 salvageV6 Daily Driver Joined May 25, 2001 Messages 20,990 You are probably at the point where Direct Scan on the car can answer questions about what you need to do better than the internet. I'd consider that setup before new injectors.
May 23, 2006 #8 TurboTnZ06 Go on red! Joined May 7, 2002 Messages 3,847 I'm running 60/65# motrons with the stock ecm. If you are only running low 11's then the 55's should be fine.
