Best injectors for TE45a???
hboost
Banned
I currently have 55lb. injectors and was wondering if I should upgrade since I'm swapping turbos and am going to be using a 45a. Any thoughts, comments, suggestions, recommendations?
What is your boost level ..... hp level......? If you have all the right parts.... the TE45A is an easy mid 10 sec turbo..... 50# is light IMHO......
72# or so would be good ones.......
My engine has stock internals, and max. boost I want to push is about 23lbs. I'm not really interested in maxing my car out, maybe mid to low 11's.
You are probably at the point where Direct Scan on the car can answer questions about what you need to do better than the internet. :cool:
I'd consider that setup before new injectors. :)
I'm running 60/65# motrons with the stock ecm. If you are only running low 11's then the 55's should be fine.
