Best Turbos?
Well back to the basic turbo regal stuff, at only 22psi your really not going to gain much from a turbo swap, you would have to ring it out more
The t-netics 60mm is a real fast spooler, what converter is in there? bring it up to 26 psi it will be a different turbo, ( monitor knock)
also your alky nozzle is too far away from the Throttle body
find out what ECU you have. 63 will be done at 500 crank HP you will need to know a lot more about this car
Fuel pump, fuel pump wiring. Your T-netic has a room to grow, Ally pump needs to be in top health for more boost. Is it?
You need to pick a ET, HP number a direction you want to go. Then see what parts in that puzzle you have.
If your puzzle box has a picture of you doing wild wheels for gapping a Damion at the finish line. I don't think you have all the correct pieces in your box . and it's not just a turbo that will get you there.
