Best place for second nozzle?
OneLethal87GN
R.I.P. Lethal GN
I'm sure this has been asked before but my computer is acting slow so I'll make a new post. I have the SMC single nozzle kit. I also have a front-mount. The nozzle is mounted in the usual place, the middle bottom-side of the stock up-pipe. Where is the best place to mount the second nozzle when I upgrade to dual lines? Thanks.
Anywhere. Location is not important with alcohol. Its just a cosmetic deal. As long as the nozzles are higher than the tank.
HTH
Does it matter if the nozzles are behind or in front of the TB, in terms of atomization and max heat removal from the air?
With alcohol..doesnt matter. Water is a different story.
After throttlebody.. requires a solenoid.
What works for all, before throttlebody on a "Turbo Buick".
HTH
