Bruce Urie
The Ventures,CCR forever!
- Dec 30, 2006
I'd like to ask you guys: where's the best place to hook up a boost/vacuum gauge? I'm thinking of ordering the AutoMeter 30in/30lb 2 1/8" gauge and putting it on the A-pillar. But after looking through a lot of threads here about the gauge, I still can't find out where to get accurate readings. One guy says remove the pipe plug, front lower part of intake manifold and replace it with a like plug for gauge...I get that, can't find this plug, another says pass side rear of intake manifold with T-fitting...very, very hard to get to,(I'm old, not Gumby
) then another place is unused port behind fuel pressure regulator, with direct signal to inake vacuum. I can't find that either.
Jeeze, am I a dweeb or what? Would I get accurate vacuum and boost readings if I tapped into the line that my boost light on the instrument panel operates on? This is the passenger side, fender, and I think that sensor is the MAP sensor the boost light gauge works off of. I'd like to have both the light and the AutoMeter gauge work at the same time. I'm well aware of, thanks to you guys, that the factory boost light is notoriously inaccurate.
So, any suggestions here guys, little help? My Grand National is mostly stock, with a few modifications. Would love to hook up an accurate boost/vacuum gauge see real boost in lbs and the vacuum for tuning. I sometimes feel like a real dweeb talking with all of you pros but even a dweeb has to have someone to turn to.
Thanks kindly.
Bruce '87 Grand National
Thanks kindly.
