Best plug choice
eagleguy
What would be the best brand and gap for plugs needed for the following mild additions or would stock plugs be just fine?
TA49 turbo
36# injectors
160 thermostat
100# valve springs
turbo tweak chip
hot wire upgraded fuel pump
It doesn't matter which of the offered plugs you use. You won't need to reduce the gap from .035" until you're making a lot of power with a lot of boost. Then again,your ignition system will let you know when it's time to reduce the gap.
Just found that my car has Autolite 24 spark plugs which I have never used in any of my cars so I don't have an opinion. In my older Buick I liked the way NGK's held up as compared to the AC Delco which seemed to foul easier. What is the difference between the NGK YR5 and the NGK UR5?
