A rookie wants to know the ins and outs of proper tactics in obtaining best launch and times in detail. Thanks
1. Go sit in the stands and watch a few cars.
2. Watch the cars go down the track and see where they turn off at.
3. When ready to make your first pass, line up in the appropriate staging lane. Usually the announcer will identify which lanes are for cars on slicks, radials, motorcycles, Jr dragsters or No time posted.
4. If you have street tires on the front, drive around the water box and then back into it. Get the tires wet and then pull forward out of the waterbox.
5. When the guy working the tree tells you to. Do your burnout. I leave my trans in 2nd gear while doing the burnout. I read somewhere you have the highest line pressures in 2nd. No need to impress the crowd. 3-5 seconds of white smoke will do.
6. Pull forward until the top bulb on your side of the tree is lit. You are now prestaged. It is important to do this with the front tire, not the back tire.
7. Once the other driver, if there is one, has prestaged--slowly inch forward until the 2nd light is lit. You are now staged.
8. Powerbrake the car to the desired boost, usually as much as the brakes will hold. The lights will come down. I usually let off the brake as soon as the last bulb before green lights up. Hold it to the floor and hold on.
