 - Mar 1, 2013
I bought a champion stock intake from a board member that I smoothed out the exterior before I take it to powder coat. I also picked up a precision plenum that I polished and smoothed out the inside. Champion billet fuel rails, I also picked up a RJC plate and 65mm polished TB from a board member. Also EGR block off plate, 2 plenum gaskets, billet thermostat housing kit, and billet vacuum block from GBODYPARTS.com. What is the recommendation for gaskets and sealers for everything from the intake up? I thought about the fel-Pro 1200 intake gaskets and separate valley pan. Is that preferred? Any other hardware/fittings, ect that I should grab before throwing this on? Hose nipples? I also grabbed up a set of the raised lettered valve covers that I smoothed out for powder coat, gasket and sealer recommendations for those? I appreciate your input.
