Silver Ghost
- Apr 17, 2013
What is the correct placement of the keyway, trigger wheel and timing marks in relation to each other on a BHJ damper? Should common internet advice prevail by ensuring that the edge of the keyway lines up perfectly with the leading edge on the harmonic balancer. Or, should the BHJ tech sheet be followed by having the "trigger wheel oriented with the transition from a raised tab to a slot opening at 55* CW from the keyway centerline"? Also, if my used BHJ externally balanced harmonic balancer needs to have its trigger wheel repositioned, who is recommended for this?
