Dec 27, 2006 #1 4 49-blues Active Member Joined May 30, 2001 Messages 7,628 Are these basically the same? If not- what are the differences?
Dec 27, 2006 #2 M Mac in SD Active Member Joined Jan 20, 2002 Messages 2,905 Completely different. BHJ makes one that will bolt right up, including interruptor ring. Fluid Damper does not (as far as I know.)
Dec 27, 2006 #3 4 49-blues Active Member Joined May 30, 2001 Messages 7,628 I just picked up a fluidamper on ebay and was told it will work with a turbo stage2. Isnt there just one bolt in the center of the balancer?
Dec 27, 2006 #4 750H.P.V6 Brutal 6 Racing Joined Sep 4, 2001 Messages 3,610 The damper you bought will physically go on any Buick V6 crankshaft but the BHJ balancer is designed to use the stock crank trigger ring and bolt circle so the stock lower pulley will fit. Neal
Dec 28, 2006 #5 4 49-blues Active Member Joined May 30, 2001 Messages 7,628 Thanks Neal. I have some of the pulleys needed to run a dry sump and they fit this balancer.
Dec 28, 2006 #6 750H.P.V6 Brutal 6 Racing Joined Sep 4, 2001 Messages 3,610 As long as the parts you've got all configure together you should be in business. Good Luck Neal
