Big Parts List and parted 3 more cars 86 Limited 87 T 87 Clone
Here is the list of parts I need thus far: Tail lights that aren't cracked (would be nice if they had black trim already), belt tensioner, armrest door (color doesn't matter since I only need the latch part), complete GN style door handle strap mounts (everything but the upper door skins and straps), turn signal lever, gray horn button with the Buick emblem (not the T emblem), trunk lid spring, hood shocks, original black carpet, a good power steering pump if possible and I think that's about it for now... Everything is for an 87 GN.
E mail me direct at Fortune628@aol.com I have alot of those parts and I will give you a package deal.
I am looking for the bracket and grommet for the shift cable where it passes through the floor pan and mounts on the transmission tunnel. Out of the thee cars you have, do you have one in good shape?
-Original GN Quarter extensions for car with spoiler $40
-84 Red upper door panels $80 minus chromegray strips $50
-Grey T-type upper door panels no chrome strips $50
-87 Maroon upper door panels $50
-Drivers side Blackout head light bezel $40
-Chrome head light bezels painted black $40 for both
-Black trim Marker lights $40 each
-Blackout wheel well moldings $30 each
-Chrome(Regal) wheel well trim moldings $40 each
-84-87 T-type header panel with hole filled $150
-84-87 T-type GM header panel, has some small imperfections $125
-84-87 Grand National GM header panel, has imperfections $125
-Passenger remote mirror(needs paint) $60
-87 GN seat belt set(10 pieces) $150
-84 GN steering column with tiltcruise $150
-Maroon steering column with tilt cruise $150
-87 GN grey column with tiltcruise $150
-87 grey column(shifter on the column) $100
-84 Blue column(shifter on column) $100
-84 tan bucket seats $250 with rear seats $300
-86 blue 86 442 bucket seats $200
-85 Gray 442 bucket seats $200
-Gray Monte SS bucket seats $200
-85-87 Gray concert sound lower door panels $100
-GN Dash Plaque $75
-84-86 T-type dash plaque $50
-86-87 Upper intake(dog house) $30
-86-87 throttlebody complete(sensors,throttle lever, vac manifold) $100
-86-87 bare throttlebody $40
-86-87 Up pipe $25
-86-87 Cruise control assembly $40
-86-87 Water pump pulley $25
-86-87 Main accessory bracket $70
-86-87 Y bracket on back of Alt $35
-86-87 Flat Y bracket on front of AC compressor $35
-86-87 Intercooler brackets $25 each
-86-87 Coil bracket ( The horse shoe shaped bracket) $30
-86-87 Power steering res. bracket $20
-86-87 Power steering pump $75
-87 GN Electric fan $50
-84 rad shroud $30
I have every piece for 84-87 GN engines(stock) E mail if you dont see it.
-84-85 Non key locking t-tops $150 a set
-Astro roof complete assembly with wire harness, switch etc. $200 wont ship
-Bigger then stock front sway bar $70
-Fuel sender fuel hanger(analog gauge) $40
-BQ tranny $350
-D-5 convert $75
-87 chrome grill painted black(looks good) $100
do you have a front impact strip?
Do you have the long plastic trim that ar at the back of door jams that goes over the 1/4 window panals and lower 1/4 panal back there ?
Do u have any tilt/cruise control steering columns for a floor shifter car. Red/maroon in color preferred but not mandatory.
