Intercooled88s
Moderator
- Aug 10, 2004
Still in need of this harness if you still have it, please.
Im going to have to look, I sold some engine harnesses recently and I need to see what I have left.
SignUp Now!Still in need of this harness if you still have it, please.
Gotcha, I appreciate it.Im going to have to look, I sold some engine harnesses recently and I need to see what I have left.
I have them $6 shipping included for both.
Could I get some pics of the black out qt Windows. 71gsx@att.net
Sorry didnt see this til now. I will take them. Shoot me a pm
I do. Sent you a PMLet me know if you still need them.
-New PUI ABS backed head liner Maroon for T-top car $160
-New PUI ABS backed head liner 84-87 Tan for hard top $160
-New Visors In 85-87 GN gray, Maroon, and tan $90 a set(these are new not recovered)(they dont have a mirror on
pass side)
-New ABS Rear Bumper fillers $200
-NOS GM black wheel well moldings(both front and drivers rear) $200
-85-87 GN gray dash speaker cover, in really nice condition(no cracks looks close to new, but has a slight warp
in the middle $150
-85-87 GN console $300
-85-87 Gray console $300
-84-85 Billet vac manifold(part on top of throttlebody) with prevision for vac brakes $30 shipping included in
the US
-86-87 GN center caps $20 Each
-87 GN dash pad(no cracks and color is nice)$180
-Power Master $300
-Mega shifter for Turbo 350 $75
- gray 442 bucket seats $250
-GM crate motor 350 block # 10066036 4bolt mains Edelbrock carb and intake, headers, comp cam 1.6 rockers etc.
$800
-nice set of 85 Maroon bucket seats $300
-New tranmission shifter cable(after market that fits properly) $18
-Turbo Riviera Turbo $200
-109 turbo block std bore $350
-Good std/std turbo crank $300
-86-87 Engine wire harness(no injector harness) $200
-New after market cruise control shifter lever $30
-Dash plaque for a GN in driver condition $40
-86-87 stock turbo, very little play $250
-84-85 stock trubo, very little play $150
- 84 GN front seats(leather and cloth) need to be recovered $200
-86-87 T-type rims(no center caps) $300 for 4 or 1 for $100
-BRF 200 4r $500
-NOS Turbo 6 emblem $50 Free shipping
-86-87 original MAF(not Rem.) $90
-86-87 AC compressor $100
-87 Intake manifold(lower intake and upper dog house) $200
-Rad hold down plate $35
-Front license plate bracket $20
-Doors $300 for set(1 pass and 1 drivers) Pick up only, I wont ship these.
-Vac brake set up $125(master cylinder, power brake booster, and correct pedal)
-87 442 Passenger side New rear quarter -Make Offer
-gray 87 442 bucket seats $250
-locking T-tops $200 a set
ENGINE PARTS:
AC compressor(84-85) $40
AC lines(84-85) $40
Adaptor(86-87 oil return to block, brass adapter,screws into block in front) $20
Adaptor(85 Turbo to intake adaptor) $40
Adaptor(Oil cooler adaptor with nut) $35
Air Cleaner scoop(86-87 Scoop for airbreather) $20
Air Cleaner assembly(86-87) $25
Air Cleanerassembly(84-85) $20
Alt.(86-87) $60
Alt.(84-85) $30
Balancer(Turbo harmonic balancer) $80
Battery cable guide(Small plastic guide that holds the posi bat cable to the lower front cover)
$20
Block(109 Block) $350
Cam position sensor just the lower part(no cap) $35
Cam position (sensor with cap) $65
Coil pack(84-85) $40
Coil pack(86-87) $25
Control module(84-85) $50
Connecting rods(2 dot) $40 a set of 6 or $10 for 1
Crossover pipe(84-85 Exhaust crossover pipe) $35
Dip stick and tube(86-87 dipstick and tube) $50
Dip stick and tube(84-85 dipstick and tube) $30
ECM(84-85 ECM) $40
EGR plastic cover $5
Elbow(84-87 Turbo elbow) $25
Flex plate(84-87 Turbo flex plate) $25
Fuel rail(84-85) $25
Fuel rail(86-87) $40
Heads(stock 8445 heads needing rebuild) $50 a set
Injector harness(84-85) $35
Intake manifold(86-87 Upper intake manifold)$35
Intake manifold(84-85 GN intake) $40
Intercooler $45
Intercooler brackets both for $45
MAF(84-85 MAF) $40
Main accessory bracket(86-87,the big alum. one) $70
Main accessory bracket(84-85) $40
Motor mounts(metal, frame mounts) $35
Oil pan(Turbo oil pan) $40 each
Power steering pump(86-87) $70
Pulley(86-87 Water pump pulley) $25
Pulley(86-87 Alt pulley)$20
Rock arms+shafts(stock, complete set) $35
Throttlebody(84-85 Throttlebody with TPS,IAC motor,vacuum manifold) $40
Throttlebody(86-87 Throttlebody bare) $35
Throttle bracket(84-85 Throttle bracket) $20
Throttle cable(84-85 Throttle cable) $30
Timing cover $35
Valve covers(set of 2) (84-85) $30
Valve covers(set of 2) (86-87) $50
Vapor cannister $10
Wire harness(84-85 engine
ENGINE PARTS:
AC lines(84-85) $40
Alt.(86-87) $60
Alt.(84-85) $30
$20
ECM(84-85 ECM) $40
Intercooler $45
MAF(84-85 MAF) $40
Timing cover $35
Vapor cannister $10
Wire harness(84-85 engine wire harness) $150
Still waiting on pics of the quarter windows.
