Big parts list,mostly stock stuff
broke1
Banned
All parts are off of 86-87 Turbo Regals unless noted!!!
2 GN decklids,1 w/ emblem,1 w/o $100 each
1 Rosewood decklid $100
1 blue/green decklid $100
5 black cowl pieces $30
3 GN trunk strip $30 (piece between back glass and trunk lid)
1 blue/geen trunk strip $30
2 sending units w/ pre bent hard lines $100 each
1 remote DS GN mirror $30
1 set remote mirrors,DS and PS,gold in color $60
2 convertor covers $40 each
4 86-87 positive battery cables $25 each
3 GN console plates $60 each
1 woodgrain console plate $40
1 set of 86-87 valve covers $50
2 stock uncut turbo sheilds $45 each
complete GN dash w/ power trunk release and ducting,GN dash plaque $225
complete GN dash w/ducting,GN dash plaque $225
complete grey TR dash w/ ducting Regal dash plaque $175
speedo w/ 01962 $60
speedo w/60894 $75
speedo w/ 42422 $80
speedo w/ 48080 $80
2 stock GN air box's $40 each
2 complete core supports w/ X brace and brackets $120 each
1 cruise assembly w/ bracket and cable $50
3 radiator hold downs $60 each
3 upper IC pipes $15 each
2 GN steering wheel cores
1 GM reman stock hot air turbo $125
2 sets of stock 84-85 GN VC's(PS sealed)$40 each
2 HA intakes $75 each
3 sets of 86-87 AC lines $125 each
2 stock GN tanks w/ sending units,1 w/ hardlines,1 w/o $150 each
3 dash bezels w/ rear defog $75 each
1 dash bezel w/ PS mirror $75
1 dash bezel w/ ps mirror and rear defog,small led hole $40
3 radio surrounds $25 each
2 rear middle fillers $20 each
5 charcoal canisters $15 each
complete tail light harness $40
1 84-85 grille w/ T Type emblem $75
1 black dash cluster surround $65
3 stock ds hangers $15 each
3 map/relay mounts $40 each
3 dash harness' $40 each
several sets of blackout trim 1/4 glass $125 per set
1 set of chrome trim 1/4 glass $120
4 floor shifters $75 each
1 IC fan $60
2 known good Powermasters,complete $150 each
1 core Powermaster,complete $100
1 core 86-87 longblock w/o oil pan $500
1 std bore 109 $300
1 turbo crank std/std $140
1 set of turbo 2 dot rods w/ SPS bolts $40
1 86-87 wiring harness,a bit cut up but perfect for a hybrid,bought from a board member from HI a couple of years ago, $90 shipped
1 brand NEW Full Throttle BSTC w/ new Caspers WG y harness and extra boost solenoid $175
TRADES ACCEPTED!!What ya got?
Everything is in good driver condition out of low milage cars and will clean up nice,if youre unhappy for any reason,I will refund your $$$ after I have the part back in my hand(had someone parts swap so I will not refund till the part is back in my hand and I can verify it is what I sent you)All parts are plus shipping unless otherwise noted.Paypal prefered and please add 3% to cover fees.Thanks,
Drew
Interested In A Few Things.i'm In Memphis,where In Alabama Are You!!!!
I would like to be first on the list for the 86-87 engine wiring harness. I am doing a hybrid project, and this sounds like it will be perfect for my application.:smile: could you tell me what is cut on it. Thanks James
Its already packed and im not pulling it out of the box.Its all there,from Haiwian Turbo on this board.From the best of my memory,it has had a length of bad wire replaced.....
If you were to buy just the connectors on this from Caspers,youd spend over $200.Ask me how I know...lol
NO pics.Theyre in good shape with mirrors,gold in color.
I WILL NOT BE OFFERING ANY PICS ON ANYTHING.I WILL SAVE PICS FOR Evilbay!!My shop is about 1 hour away and I wont be going there till I pickup stuff to ship.The 2 hours worth of driving for a pic and somone not buying the item would be a big waste of my time and $$$$ so I cannot justify them at this time....
where to send paypal.
I will take the engine wiring harness. Where do I send paypal payment to. Thanks, James
I beleive I have 2-3 of them, $24 shipped.
Remote mirrors are sold
Thanks,
Drew
trunk piece
how much shipping to 36092, its a business address also, plus i may make it to hoover for that al turbo buick club meet on the 16th of this month.
dash plate
Hi, I'm looking for the dash insert above the glove box for a GN, the previous owner drilled out mine for gauges, do you have one? thanks, paul
powermaster
is the unit you have complete and reday to install?leave me a pm thanks jim
are they just the speedometers do you you have the instruments cluster also? I don't need the bezel.
