Several quarts of fluid and the ability to get the filter lower so it doesn't get uncovered with hard acceleration. The ones I have seen lately have been in the $215 plus shipping range.
Here is a piece by Don Wang(alkyv6). A few paragraphs in it has info on the filter and deep pans.
I use a stock pan and 700r4 bottom feed filter. Mostly due to budgetary constraints. I would like a fabbed up pan and custom bottom feed filter but it just doesn't fit for now.
I use one of these but came powdercoated black with the fins aluminum. Might have come with a filter too, can't remember. Not one leak ever and drain plug is a blessing.
Interesting read. I wasn't aware you could use a 4L60 bottom feeder. I believe most use a 700r4 filter. Is there any advantage with using a 4L60 filter instead of a 7004r?
