T63E
3" d/p and exhaust
msd 50's, LS1 maf & xlator plus
BGC Stetch IC
Art Carr 9" non lock up.
Every thing else is stock with 104k miles on it
With slicks, race gas, 26 psi and low timming:
60': 1.698
1/8: 7.27 @ 97.1mph
1/4: 11.30 @ 118.6mph
On the street the car is a pig from a dead stop. Not enough motor to snap that big turbo over none to quick. BUT!!! this is good because as soon as it does the car goes nuts roasting the tires. What would be perfect is if it would hit lets say 5#'s real quick and then go from 5#'s to 20#'s at a slower pace to keep the tires hooked up. Once your cruising along the lag is reduced alot. Power comes on both quick and hard at any thing over about 30 mph. One draw back is I heard the 63's have a sweet spot of around 26#'s of boost. I personaly found out its pretty much true. If your willing to put some good juice in the gas tank and turn the boost up to the 26# range or so I say go for it. If you dont like boost that high then I think you should go with a quicker spooling set up. One more thing I have made a run out on the steet at 30psi, had the fuel right, and it was cool out. MAN! the car felt like a run away freight train. One day I think Ill try a full pass at the track at 30psi.
Big turbo, big intercooler, high boost, fuel dialed in, decent launch......your going to go fast, stock long block or not.
HTH: Jason
