biggest turbo possible
Try the search feature, there are a million posts on this subject, this question gets asked once a month on here. The easy answer is anything that will fit in the 87 compressor housing will fit under the hood and clear everything. The biggest you can fit in those housings is a TA64/66. If you plan to run it without an intercooler you will have to adapt the outlet of the turbo to the intake manifold. Or you can run the stock hotair compressor housing which will hold a TA62 and bolt straight up but there are stories of oil control problems with the bigger wheels in the hotair housings.
The 60lb injectors are great because they're cheap and work with the stock computer. I don't know anything about your particular turbo but I believe the 60s will go to over 600hp at the flywheel.
Matto said:
Anybody ever fit a TE model on there car?
I'm sure you might be able to make it work but it's a lot of trouble for nothing when you can get a TA series turbo to make 700hp.
