Bilstein front shock washer stack up help
viokrome
Just got a set of bilstein front shocks 24-009492 and wanted to know what the washer stack up should be, I know the small hole silver washer goes on bottom then a bushing up against the botttom of the a arm and the black washer goes on top with a bushing under it , but there is a third washer with a lager hole I am not sure where to place it?
Mine didn't come with instructions either, and I installed them pretty much the same way as you. Just left that third washer out.
Thanks, I think I will take that third washer out, I really dont like the metal on metal contact that third washer makes on top of the a-arm.
