Blazer Brake Setup
mjdwyer23
Woosh WaGoN
I have a set of 1999 Blazer 2WD spindle assemblies including 11" rotors and dual piston calipers off of a 69k mile truck. There are a direct bolt on to the stock mounting points and only require two Weatherhead 7818 adapters to bolt the brake lines together. I just did this swap on my car and picked a second set up from the boneyard when I was there. I swapped in the gbodyparts tubular front upper control arms too while I was there, piece of cake! These will clear stock wheels and give you a boost in braking without breaking the bank! 275 (what I paid) for the assemblies plus shipping, which will be around 50 dollars to the continental US.
Imo
That is a good buy. I see you got the mounting brackets (the place where the flex brake line joins the hard line) I have done this swap and these brakes are the answer. Best of kuck.
Yeah the frame brackets prevent having to bend (and possibly ruin) your hard lines.
G-bodies and newer s10's as far as i know. Definitely a great improvement for the money.
