NoVA_87_GN
Hoping to get some clarity.
I've read through a bunch of posts, but I seem to be having an issues bleeding my front brakes.
I have powermaster setup with the acc ball, I pumped the brakes 10 times to get all the brake fluid out of the ball. I bled the rear (had to replace rear cylinder assembly and hard lines, not fun). Got good clean steady fluid coming out of them. Moved to passenger front, seemed to trickle out at first, but i got nothing now. Opened the driver's front bleeder, same thing, no fluid.
I am using a handheld vacuum gun to try and pull the fluid through, but no luck.
My question is, do i flush the front brakes with the acc ball empty or do i need to power it car on and get the fluid sucked back into the ball and bleed them from there?
This is my first time bleeding the brakes on the Buick, I've done it on older gm A-bodies/mustangs with no issues.
Thanks in advance for any help, this the last thing i need to do before i can get her back on the road for fall.
