BLM inputs
hounddogs!
What sensors are providing the info so that BLMs can be calc'd? With high speed / high air flow and the cracked DS header, my BLMs are 147+. If the O2 sensor (the only measurement downstream of the header) is part of the mix, I'll assume that that fixing the crack next week will help the BLM issue. If the O2 isn't factored in, there's a vac leak on the intake side, correct?
TIA
