You SHOULD be concerned with cell 15 despite using a BLM patch. Heres my opinion why:
Cell 15 learns 140. The ECM has learned to add 12% fuel. Now you lock it to 128. Now you have to raise the fuel pressure to regain that 12%. Now what happens to the rest of the grid? whoops, all the work you did and the grid is back down to where you started.
If you ask me, and you didnt, I would tune the car so there is minimal corection being made across the board. The deal with 009's is pretty much this. Below 7mS PW's they act almost 70% larger than stock. Over I think it was 12mS they start copming back down and act like the 46% or whatever larger than stock they are. I personally use a 2Eh as my constant (I think ~44.1) which is kinda in between where you are. When needed I will trim some fuel out of low op MAF, but so far most of the cars I've set up fall in around 120 on the idle BLM and 130-135 max as you get into the higher blocks.
As for PE trims, I'm a little leaner than you. I go like -15, -8, -4, 0, 6, 18, 30, 55 or something to that effect (I max the injectors at 6400 so when the ECM interpolates the values I should have plenty of fuel). This seems to help with the "fattness" of the 009's and gets them to spool quite well. I also like to use WG ramp and timing to aid in spooling.
I guess there are many ways to catch a chicken. I have my own which seem to work well.
