Block Mods
carhell
What mods need to be done to a 84 hot air block to use for 86 set up? I already have the heads and intake for the 86 motor. Any input is appreciated.
The only mod that you'll have to do is a 1/2" npt tap for turbo oil return line. Some have run the line to oil pan and not tap the block. The heads are pretty much the same and a swap is not really needed.
+1 to the pan
Number 10 AN fitting welded the upper/passenger front of the pan, some push-loc hose right up the the under side of the turbo. Easy:biggrin:
