278cikiller
- Dec 21, 2007
Friend of mine has a blow off valve on the up pipe and the vacuum line from the blow off is tap into the fuel pressure regulator vacuum line is his a good idea,the car knocking when you get gas is this normal, also it has a hot wire kit on the side of the fender wall with two pumps in the tank and a hob switch and the relay is plug into the gray wire behind the alternator to work one of the pump's is this a good set up or has any one done it this way? any info would be great thanks.
