The rear cylinder on the passenger side is leaking coolant into the valley. I lost a lot of coolant, I'm not even sure when it happened.
I'm going to pull the motor, what parts should I replace while I'm in there?
main, rod, and cam bearings!! been there done that. run water and water wetter from advanced auto then put in antifreeze for winter storage. that way if it happens again the water wont hurt the bearings u just pull the heads and let the water evaporate and all your left with is oil. then invest in an alky kit from Alkycontrol it is the bomb i am at 27 psi 808 o2's no knock this car is rippin
just inspect the bearing and see if they need to be replaced. as far as that new gaskets and that about it. I would start Running RMI25 and distilled if i where you.
