blown head gasket?
klcsmooth
I think I hurt my car I was racing a honda 2000 sunday I won the race by a wide margin{10 car lengths}when I was crossing the finish line I saw smoke out the tail pipe.When I popped the hood I noticed that the oil fill cap was off and there was pressure out the oil fill tube.I also notice oil leaking from the three bolt turbo header connection. I pulled the plugs driver side had oil on them.I then did a compression test 150 on 3,4,5,6. Compression on #1 90 #2 0!!!! I know this has to be the problem but what causes this piston/rings or hg.
headgasket sorry
you said 1 and 2. man that sucks both sides. humm let us know what you find.
blown head gasket
rjc hg 1, #2 piston 0. Seems as though rjc hg hold more pressure than stock piston. Looks like piston blew up on one side. no damage to block wall I most have turned it off in time. I dropped oil pan cleaned everything up pulled piston put in one of my extra pistons.I should have everything together tomorrow I will see what happens.
i knew you where in for s suprise i just didnt want to post it. as soon as you said 1 and 2 and one of them being 0 and the other one was 90 i knew something bad was in store.
