Stored since the late 80's by a Buick Landspeed World Record Holder these items are now available:
Several (9 and possibly more)
RAW CRANKSHAFT FORGING P/N 25500008 COST: $575 + Shipping - This unmachined even-fire crank forging give Buick V6 engine builders the freedom to use non-standard stroke dimensions. It is forged from tough 4140 steel (30-34 RC Hardness), and it will accommodate strokes from 2.66" to 3.625". The extra-large counterweights will provide proper engine balance with heavy-duty piston/rod assemblies.
Forgings have a fair amount of surface rust. The rust will not affect the integrity as much of the material will be removed. These forgings will require machining at your expense. I can ship several to a machine shop such as Moldex if several people wish to coordinate the machining of these at one time. I'm sure Moldex will reduce their machining fees based on volume and tooling set up time.
Again $575 + Shipping fees
Other semi finished cranks are available in sizes 2.66-3.06. Call for more information.
Several sets of Stage II aluminum and steel heads available. He is asking $825 for a set of heads.
Thanks,
Tyson
turbobuick87@hotmail.com
831-438-3100
Thanks,
Tyson
831-438-3100
