body side molding?
Turbo Steve
was body side molding installed at the factory or dealer installed? is it listed as a code on the trunk tag? mine is the stick on type and can it be easily removed for a cleaner look?
Yes. Usually the dealer installed molding was the aluminum trim with pop rivets.
If installed from the factory, yes. I can check for the code if you need it.
Yes. Somebody will probably chime in with the exact product but I believe 3m makes a good product for this purpose.
Body Side Molding RPO Codes
Here are the RPO codes for the body side moldings.
B88-All GN and WE4. Solid black
B84-All except GN/WE4. Color insert with chrome mylar edge.
B81-Body side molding delete.Only used with W11/WE2/WE4/W02 codes.
