May 13, 2011 #1 J john piet New Member Joined Jan 3, 2010 Messages 12 I am looking for an original type body side moulding for an 86 gn. I need the piece that goes on the drivers side rear fender, It is about one foot long.
May 20, 2011 #2 turbo87regal Member Joined Nov 12, 2005 Messages 356 Are you talking adout the style that is riveted on and Where are you located?
May 21, 2011 #3 J john piet New Member Joined Jan 3, 2010 Messages 12 bosdy side moulding The body side mouldings are taped on with 3M double sided tape. I am located in citrus springs florida. You could call at 7346649135. if you want.
May 21, 2011 #4 turbo87regal Member Joined Nov 12, 2005 Messages 356 The pieces I have are the riveted on frame with the rubber inserts:frown:. They came with either the stick on or riveted type witch is why I asked. If I was you I would probably try gbodyparts.com or a bodyshop supply store. Good luck.
