i bet you 10 bucks when you turn the rjc nothing will happen, my vote is for the rod depending on how much more boost you want. nothing against the product it just doesnt seem to like certain combo's
You will get more boost out of the RJC controller if you take it apart and stretch the spring. I was running 27psi with a stock actuator. The rod was set so loose, I barely had to pull to connect it to the puck.
i tried streching the spring, and putting a heavier spring with shims in with no luck, i never figured it out, so i just tuned the rod a few times and got to my goal of 26psi, never figured out the issue with the controller though. i have seen a few others with the same problem, maybe its something in our combo
