Feb 18, 2004 #1 B BigTom New Member Joined Nov 21, 2003 Messages 18 Which vacuum line do I install it on? I have the two line wastegate. Is it the side that the arm is on or the other side?
Feb 19, 2004 #2 T Turbo Loyd Member Joined May 26, 2001 Messages 343 Rear line on dashpot The rear line (nipple away from actuator rod) actuates the wastegate. The rubber hose from the front nipple (nearest the actuator rod) may be removed with the nipple at the throttle body capped off.
Feb 19, 2004 #3 B BigTom New Member Joined Nov 21, 2003 Messages 18 Re: Rear line on dashpot Originally posted by Turbo Loyd The rear line (nipple away from actuator rod) actuates the wastegate. The rubber hose from the front nipple (nearest the actuator rod) may be removed with the nipple at the throttle body capped off. Click to expand... Cool thanks, but what does the line nearest to the rod do?
