Boost solenoid hookup for ECUGN
MN250R
Hello, im looking to hook my factory boost solenoid back up. Right now its hooked up "tuner style" with a lorenz manual boost controller. Trying to find a drawing or diagram for where the vacuum lines go from the boost solenoid to the turbo/wastegate so i can control it from the ECUGN tuner software. Thanks
The stock wastegate is a single-port that used a vacuum Y fitting with a restrictor in it. If you don't still have that part, it won't work. It doesn't work that well anyway.
You want is this valve:
You can wire it to the stock boost control wiring, it's plugged into the right input for the electronic boost control in the ECUGN.
Great, Thanks!
Legit Mac dealer, got a solenoid here this Summer $24.
The slick part is you can use the stock wastegate wires to hook it up to EcuGN and it fits right in the same spot as the stock one did.
