Boost solenoid hookup for ECUGN
MN250R
Hello, im looking to hook my factory boost solenoid back up. Right now its hooked up "tuner style" with a lorenz manual boost controller. Trying to find a drawing or diagram for where the vacuum lines go from the boost solenoid to the turbo/wastegate so i can control it from the ECUGN tuner software. Thanks
The stock wastegate is a single-port that used a vacuum Y fitting with a restrictor in it. If you don't still have that part, it won't work. It doesn't work that well anyway.
You want is this valve:
You can wire it to the stock boost control wiring, it's plugged into the right input for the electronic boost control in the ECUGN.
Great, Thanks!
Legit Mac dealer, got a solenoid here this Summer $24.
The slick part is you can use the stock wastegate wires to hook it up to EcuGN and it fits right in the same spot as the stock one did.
Thanks, i actually tested the power to the two wires that are in the red clip that connects to the stock solenoid, i didnt get any, with either the key on, or running, so i ran the wires from the solenoid to a switched 12 volt source, and the computer wire. Wasnt sure what wires to tap into to make this new solenoid work. Thanks!
My stock boost connector was originally like yours so we used maybe the old evap can connector in stock location.
Then when I swapped to the Caspers Engine Harness I didn't bother moving over.
