b4black
- May 24, 2001
I have heard several people comment that they can get up to 10, 11, and even 12 psi by "keeping their foot into it". I was seeing this also. If I removed my exhaust and replaced the air box with a K&N cone, I could get up to 12+ psi with no problem. This isn't what is supposed to happen! The stock wastegate actuator should limit boost to 9 psi and no more. If it goes much higher, then the boost is "creeping up"
At 9 psi, the WG flapper opens and relieves exhaust pressure away from the turbine. If the hole is too small, then not enough pressure is relieved, and boost continues to rise. This is boost creep.
I am starting to think that this is a common problem. Or at least on all 82/83 cars, since in '82 the turbine was made smaller than previous years. The cure is to enlarge (port) the WG hole just a little. Unfortuanately this requires removing the turbocharger.
While higher boost is good, creeping boost is not reliable or consistent. A ported WG hole should give rock steady control, insuring the boost goes up to and not beyond where it is set.
