Boost fluttering at part throttle accelleration?
2QUIK6
Turbo Milk Jug displacmnt
My boost has started to flutter up and down at part throttle accelleration blasts of say about 10 lbs...it will flutter up and down say to 12# then back to 9# then back to 12# back and forth. It takes it about 1 second to drop down to 9 and then pop back up to 12 so its not like boost spike.
I have a BstC controller with 1 stock solenoid, with a THDP and the hole has been opened up to 15/16" with stock turbo.
Any idea what the cause may be? I just recently put on an LS1 MAF and Trans+ also and this started about the same time.
At WOT its fine, only part throttle problem.
I get the same thing when my wastegate rod is too tight. I loosened it up and added external spring(s).
Tom
Thx, I'll try loosening it up a bit as the BstC controller is barely turned to the 2nd mark for max boost on pump gas.
