boost issue HELP
87gn1
Last night I went to go wot and my boost went up to 25 psi. Myo2 reading are all over the place. My set up is stock chip turbo stock what would make this happen. Knock went up to22+ and I let out of it as soon as I seen it rise. I do not have a power logger. The knock readings came from my scan master. When I drive nice under about 15 psi of boost no knock runs good. Any advice is appreciated thanks in advance
boost issue help
No just 93 octane my boost never went above 14 this just happened last night. I checked the puck its not stuck moves freely when unhooked from the waste gate. What makes it boost so high.
overboosting issure
so this is what i have done . i removed the y fitting and ran a hose from the actuator to the turbo and left the vacuum on the cylinoid unhooked ran the car about 12 or 13 psi of boost and zero knock . im guessing that this means the cylinoid is bad any help is appreciated thanks
