I have a boost question, as I'm trying to play it safe.
I put in the Thrasher 92 a while back. (Some of you might remember reading my thread.) With the lines hooked to the wg-solenoid, it was just going way too high for pump gas and insufficient fuel system. Was hitting in the 20+ psi range. I took the solenoid out of the picture, and just controlled boost via the bleeder valve. I had it adjusted to about 16 psi and it ran strong, but it ran 16 psi all the way up to and through 3rd gear (never got the chance to hit 4th/OD).
Then I put the hose back onto the solenoid, then on the solenoid out port, I put a small hose to the bleeder, figuring it would still allow me to regulate the boost in first gear, and that it might allow it to drop down in higher gears. At the track, I got it adjusted right, and it would still spool up to 16 psi (or whatever I had it set at) in 1st gear, but it STILL stays at the same amount of boost all the way up through 3rd gear. Is this a dangerous thing to be doing? I know its a low timing chip for more boost to be safely reached on pump gas. But is it ok to run the same amount of boost all the way up? It feels fine, and pulls VERY strong. I just want to be sure.
