Went to the track last weekend and noticed that my boost was falling off at the top end of each gear. For example my boost would jump up to 18-19psi and then as the rpm's increased it would fall to about 16-17psi and then jump back up to about 19 after the shift and drop as the rpm's increased again. It does this in every gear. Does anyone have any ideas on what causes this? It is a stock turbo but I cant imagine the stock turbo running out of air on a stock unopened motor especially at only 19psi.
Also I have a THDP on it and the DP does not seal against the DP flange face on the turbo. When you look at the turbo on the car in between the top two bolts on the DP the opening on the DP actually sits higher than the flange face on the turbo creating a gap big enough to put the tip of a pocket screwdriver in and its messing up my wideband readings. Has anyone else experienced this?
